Well I pulled the tranny (again) to work on my leaky rear main seal. Good news is that the RSM I put in last month was bone dry
Bad news: My refreshed tranny is leaking from the input shaft (with a brand new seal ).
Ok, I did a search and found lots of info bout how to remove the seal with the gear stack in place. But, no real mention of how to install with the gear stack in place. Will the new seal simply slip over the input shaft and into the seal pocket?
I am doubtful because when I installed this seal last time (with the gear stack removed) I had a hard time getting the seal to seat all the way down.
Questions:
1. Any special techniques to installing the seal with the input shaft in place?
2. Should the seal sit completely flush with the housing? (I could never get my previous one to sit complete down...)
3. Any thoughts as to why my new seal is already leaking (other than the excessive pounding I gave it going in )
4. Saw an old comment from Brad about the pivot balls leaking???? I need to recheck mine when I get home...(sorry, not really a question).
Oh and yes, I lubed the new seal last time.
thanks
