QUOTE(Mikey914 @ Aug 14 2021, 08:51 AM)
Guys, the 914 engine rubber is identical to what the OEM made. If it’s larger than what you have it’s because rubber shrinks over time. It also hardens. Ours is made to a 75 durometer, my testing from older factory pieces was that they were typically 80 duro +. As it hardens it becomes more brittle. From all of the rubber parts I’ve tested, it looks like they were pretty much all of this consistently ( except the foam seals like on the outer doors)
If the rubber is fully seated in the body track it is difficult to remove even with the engine out.
I’m interested to see what the issue could be, can you post up any pics?
Also it is possible that the body track has some damage (usually from rust). I know we have had to replace a few.
It's not the body track that's the problem it's when it lips over the tinwear it won't stay on, I'm having to use gaffer tape at the top to stop the not air from rising, tried an original Porsche rubber from my friends car and it stayed on, I probably got unlucky with mine, might have to order another set and see if they fit any better ☹️
