QUOTE(Movin6 @ Aug 17 2021, 03:23 PM)
After adjusting the valves and checking the timing, I checked carb sync - The 3 barrels on the left side (Driver side USA) all read 4, while the 3 cylinders on the right are 5 or 6. Is this a linkage issue, or should I just adjust idle air to increase or decrease?
Thanks in advance!
I had this issue when I first got my car running,I had already replaced most of the worn linkage ball cups,found lh and rh thread ones new on Pelican,did a couple more and it was sorted.
I also found the throttle return springs were a bit uneven and sorted that,now after a bit more running I have found the issue is sometimes there again so I plan to fit return spring on the cross bar as others have done.
Unless all the above are correct any adjustment of air bleeds, mixture or throttle screws is only masking the problem,good luck.
