QUOTE(Montreal914 @ Aug 19 2021, 05:38 AM)
A few years back when rebuilding my engine to a 2056, I installed it on the tail pipe per installation recommendations (at angle, pointing down). Since I didn't know how the interior of the muffler was actually built, I figured, this is not the best but I am catching all of the cylinders.
Click to view attachmentI got this kit:
https://www.summitracing.com/parts/avm-30-4110Click to view attachmentI experimented a bid with different setups.
Had two sensors mounted on a Mittelmotor Exhaust, which is close to the original design. I had mounted a sensor at the passender side and one sensor in the middle of the exhaust. With the one on the passengerside you can only moitor cyl 3 and cyl 4. Even if you unplug an injector at cyl 1 or cyl 2 you hardly recognise a diffrence in the reading. The one in the middle position is still more sensitive for cyl 3 and cyl 4 but you will clearly see a diffrence in the reading if something is really of at cyl 1 and cyl 2.
Middle is also still responsive enough to run closed loop with MS.
I have also ried the Vintage Speed exhaust with the original bung position and clearly see O2 mixed in at lower RPM/Load. From that experience I would say the sensorposition in the pic above will probably not provide good results in the low RPM/Load range and it is probably also to cold for propper sensor operation and will potentially reduce the lifetime of the sensor.
So, if you use the O2 Sensor to observe if something is going wrong with you injectors, I would choose the a position in the middle of the exhaust...
