LefthandRev
Aug 19 2021, 01:07 PM
Has anybody attempted to 3D print the bushing at the firewall? If not, I'm going to take some measurements and give it a try, then post it here and thingiverse.
Should be straight forward. Inner and outer widths with a lip and a catch.
falcor75
Aug 19 2021, 01:10 PM
Just print it in something more durable than PLA.
iankarr
Aug 19 2021, 01:16 PM
Sounds cool…and I’m all for DIY but I kinda like supporting our vendors for readily available parts. Just a thought.
Chris914n6
Aug 19 2021, 01:47 PM
The nylon that the bushings are cast from is the best for the job. Nothing 3dp would be worth the trouble.
GregAmy
Aug 19 2021, 03:11 PM
bdstone914
Aug 19 2021, 03:54 PM
Why when you can buy nylon for $12 and urethane for $18?
windforfun
Aug 19 2021, 04:46 PM
QUOTE(bdstone914 @ Aug 19 2021, 02:54 PM)
I agree. Cut the new bushing wall at 45 degrees to the length of the bushing & then just slip it over the shift rod. Then push it into the firewall. BTDT.
VaccaRabite
Aug 19 2021, 04:59 PM
QUOTE(GregAmy @ Aug 19 2021, 05:11 PM)
This is the correct response. If you are trying to make a better mousetrap, this is your answer.
Zach
930cabman
Aug 19 2021, 06:22 PM
I am considering Delrin from McMaster Carr for all the bushings from front to back. It seems as though the readily available stock type replacements are ill fitting. I am not ready to go to bronze, and Delrin is looking like a good option.
