PO autox-ed the car. No, he flogged it. When I bought the car the entire underside of the car from front to back was cone-dented. Both valences were missing. Decos were trashed. Huge brakes up front. Now that the car has been restored, I have noticed huge rear studs. I installed some refinished 15 x 6 fuchs and the studs are sticking waaay out.
So far that I cannot use std lug nuts. How much rear camber can you achieve and without flares, how big a spacer can you run with the 15 x 6 fuchs? I am guessing from the length of the studs a 1/2" spacer and lots of negative camber would be required to use std lug nuts. I am resisting replacing the studs back to stock unless I have no choice.
I guess I am also curious...why someone would run these long studs?
