doug_b_928
Aug 19 2021, 09:19 PM
PET says that the screws and speed nuts for attaching the rear valence to the tail are size 4.2. I have 4.2 screws and speed nuts but the screw is too small for the original speed nut (which is also much larger than the speed nut for a 4.2 screw). I have two tails and both have identical speed nuts (the larger size). I had assumed that the holes in the speed nuts were smaller and had been enlarged over the years, but the fact that they look identical on two tail sections makes me think that the the size was originally larger than 4.2. Is PET incorrect on this one? See pic of the difference below.
doug_b_928
Aug 21 2021, 07:23 AM
Maybe I should ask, what hardware are folks using to attach the rear valence to the tail? Are you still using screws or have you switched to nuts and bolts?
914Sixer
Aug 21 2021, 08:36 AM
Use what you want. Nobody but you will know. Screw and speed nut was probably for quick assembly line work. Never seemed tight enough for me.
JeffBowlsby
Aug 21 2021, 09:11 AM
I just did this. Think it was a #6 or #8 hex head screw that went in like it was made for it. No speed nut needed. Mount the valence before the bumper goes on, which laps over the valence flange.
doug_b_928
Aug 21 2021, 09:21 AM
Thanks for the info guys.
dr914@autoatlanta.com
Aug 21 2021, 10:45 AM
4.2 is correct speed nut you have is not, should be a slide on two sided clip
QUOTE(doug_b_928 @ Aug 19 2021, 08:19 PM)
doug_b_928
Aug 21 2021, 11:12 AM
I have the slip on type of speed nut as well but didn’t see how it could slip over anything…
doug_b_928
Aug 22 2021, 11:40 AM
I think this is the kind of speed nut to which George is referring, but there's nothing to slide it onto...
