QUOTE(Optimusglen @ Aug 20 2021, 09:40 AM)
Is the system already filled and braking normally (i.e. no air bubbles in the lines, just old fluid)?
If so, just a standard smallish bottle of DOT4 would probably be sufficient.
If the system was opened or drained then all bets are off and it really depends on your proficiency with the 914 system, specifically getting air out of the ABS system for the rear brakes (often mistakenly called a proportioning valve)
Systems are full now but old on the Cayman, and I'm replacing with DOT 3 for street driving. DOT 3 is suggested for more infrequent replacement, but found no info about what is recommended for either car such as DOT 4.
