QUOTE(Arno914 @ Aug 24 2021, 12:59 AM)
From ´74 model year (USA) on the car can only be started with the seat belts put on in the proper sequence.
That is controlled by the "logic relay box" under the seat and a contact in the seat cushions, together with contacts in the seat belt lock.
Checked with my factory manual, "unfortunately" only in german.
"Engine can only be started with the seat belts on..."
thats exactly what it is.
the dreaded seat belt interlock system.
some remnant of it must still be in the car but wired "around".
disconnecting the earth has brought it back into play?
its a sh$t of a thing.
i got a migraine out of it 30 years ago.
it would be doubtful yours was still fully functional before it went into the body shop.
99.9% of owners immediately had it dealt with when new it was so horrible.
why i say its probably wired around. but the loose earth might be necessary to the wire around solution.
mine had been wired around, but the relay was still in the circuit. its just that you did not need to do seat belts up etc to start. but the relay was screwing up and cutting out when it got warmed up internally. i would get into situations where the car would not start after being warm. it would start cold. i imagine your car might have the similar "solution". so the earth being knocked out has brought it into play.
a wiring diagram for the 74 model year will sort it out.
the relay is still in my car. i could take the seat out and photograph it but its a lot of trouble and its been wired around anyway to cut it out of the circuit and incorporate a hidden kill switch.
