Hello, I have a gas smell under the hood. Lines seem good, doesn't seem to be any holes in the tank. I noticed a couple bolts were loose joining the filler tube to the tank. One will not tighten completely. (I have not looked into the cause yet) I ordered a new gasket to fit between the filler and the tank. Is there anything special I need to do to replace it or is it simply take off the bolts, remove the tube, clean the area, put on the new gasket and re-bolt the filler tube?
Do I use any sealer for the gasket?
Any info is greatly appreciated.
Regards,
Terry
