I have a '73 2.0.
I was able to pull 2 of the 3 gauges in the cluster to replace the lights that illuminate the gauges at night. However, when I try to pull the speedo it does not want to come out. It seems to have significant resistance. I'm able to pull it out about an inch, but I'm afraid that if I pull any harder I could break something or cause myself a headache.
Is the speedo cable on the back of it need to be removed from under the dash before I can pull it out?
Other tips?
Also, the center console gauges don't pull out right? What is the best technique to removing those to replace the lights in them?
Thanks in advance.
