Speedo
Aug 29 2021, 01:45 PM
Bench tested my headlight motors and they worked fine. Now assembled into the car they are unresponsive when I try to power the motors to adjust the throw. there are only three spades...red-green and grey. With aux 12v to the red, alternating the ground between my green and grey should work the headlight up and down. I have 12v to the red, but zero response from the motor. I tried connecting the ground to red and alternating the 12v between the green and grey and nada. What am I doing wrong?
Aug 29 2021, 02:00 PM
QUOTE(Speedo @ Aug 29 2021, 12:45 PM)
Stupid question, do you have the relays in the sockets?
Aug 29 2021, 02:04 PM
There is no up/down for the motor, it only turns one way ...
Aug 29 2021, 02:09 PM
Wires for the headlight motor should be green/black, gray and black.
Item (62) in this diagram
Item (50) are the relays
Item (11) the headlights
Speedo
Aug 29 2021, 04:16 PM
So my car is a six, and the wires are red, green/black and gray...would that matter?
I checked the wiring in my son's 72 1.7 and his colors are the same as mine. Maybe I have two bad relays by coincidence?
jcaps
Aug 29 2021, 06:31 PM
I just tested mine...
In the 3 spade connector you apply+12V to the red and alternate +12V to the green and grey (not ground). There is a seperate spade connector for the ground.
Speedo
Aug 30 2021, 06:07 PM
[/quote]I just tested mine...
[/quote]
Bingo...both work. Thank you! Now I can adjust and mount the headlight covers and brow and hood.
Speedo
Aug 30 2021, 06:12 PM
Meanwhile, Bullethead supplied me with a decent suspension cover that needed some love. Metal worked it a bit, took it down to bare steel and treated, primed and painted in satin black. A little bit of love with new edges from 914Rubber and we are good!
