Although the 2.0 in my car was running nicely, I wanted to get back to the original engine and transmission so that the numbers matched.
The original was a 1.7, but I decided to build it out to a 2056 with all stock DJet fuel injection.
Below are the details together with some pictures.
I am thrilled with the results. Nice increase in power, but mostly I am amazed at how responsive and smooth it is.
Original 1.7 Case
Reconditioned 2.0 crank
H-Beam Connecting Rods
96MM JE Forged Pistons
Biral-lined Cylinders
AAP Heads from LN Engineering (44x38)
RAT 9550 Cam Kit
- Intake
- Valve lash 0.0
- Valve lift: 0.426
- Duration: 262
- Duration @ 0.050" 224
- Lobe center: 108
- Exhaust
- Valve lash 0.0
- Valve lift: 0.426
- Duration: 267
- Duration @ 0.050" 229
- Lobe center: 108
Chromemoly Push Rods
Parkerized Lifters
911 Swivel Foot Adjusters
Valve Train Geometry Calculations resulted in:
- Intake: 27.047cm
- Exhaust: 27.148cm
Compression:
- Bore 96MM
- Stroke 71mm
- Combustion Chamber: 58cc
- Deck Height: 0.071in
- Piston Valve Pockets 1cc
- Compression 8.1:1
123 Distributor with Vacuum Advance
Timing 30 deg BTDC at 3500 RPM
Fuel pressure: 29psi
Stock Fuel Injection with new Standard Motor FJ67 Injectors
New MPS Diaphragm from Tangerine Racing
AFR set to:
- Idle 14.5
- Part load: 13.5
- WOT: 12.5
Replaced all 11 oil galley plugs with threaded stainless plugs
Stainless Steel Heat Exchangers
ANSA 4-port Exhaust
Cruise control
