QUOTE(bdstone914 @ Sep 2 2021, 07:38 PM)
QUOTE(9**P-car @ Sep 2 2021, 04:46 PM)
WTB: Rocker shaft end-play shims. I have checked every source I know, and all they have are Type I shims. The type 4 shaft is .8 in diameter. Setting up my valve geometry, so could use an assortment of widths. Thanks
Most people go with solid spacers.
Did you check European Motorworks in Hawthorne CA?
Yes, they are one of the sites I checked out. I have a solid spacer kit from FAT-Rimco, but just wanted to dial in the spacing between rocker arms and valves.
