QUOTE(Steve @ Sep 19 2021, 05:28 PM)
After removing the lock/handle, you should be able to easily push the mechanism through the opening and open the door.. if the mechanism is tight, remove the door panel and soak everything with WD40, while moving all the mechanisms, including inside door lock and handle.
I did all of the above with no result. So I will order new actuators (Mikey has all the stuff I need). Thanks to all of you for your advice.
