For the last few days an electrical gremlin has popped in and out. I did have a headlight ground short that was found and fixed a few days before this happening
73 914 2.0. The generator-alternator light came on and the tach dropped about 1000 RPM (still work but reading low) and the turn signals will make the tach jump with the turn signal. When running the alternator is putting out 13.95 V and with the motor off the battery tested 12.6 V. Alternator belt is just right. Fuses ok. Checking grounds. Could this be coil related problem or ???
(from face book)
U could have a bad diode in alt causing the alternator trouble light to be on and still charge and other dash lights to fluctuate bright and dim. Test using a volt meter on AC to see if the alternator is putting out AC current showing a diode bad. I would also recheck all ground connections.
So me, Putting the voltmeter on the battery with the motor running it’s showing 30 V AC which could indicate a what? If the alternator is kicking out AC do you think that’s probably the culprit?
This is a 90amp rebuilt that Clay put on for me about 5 years ago. Other tests I can do? And any recommendation for a starter/generator rebuild shop in the Fort Worth area? Thanks All.
