Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake.
To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something?
Also, will the factory rear sway bar, fit if using the 6 speed boxster trans?
