QUOTE(Mikey914 @ Sep 23 2021, 08:54 PM)
Will the lights come on when the key is in the running position, engine not running. They should work then, but in accessory position no it will not raise.
If so that is normal.
For high beams I suspect fuse, switch or relay issue. Hopefully not switch.
1. When the key is on accessories position, the lights (low beam) work and come up. When the engine is running I am unable to get the lights to retract to upright position.
2. When the low beam are on, I cannot get the high beams to work when I flick the light switch to operate high beam. Also no power come to or out of fuses #1 & 2. Ive replaced the headlight relay with new one, and also the light switch level is new.
Dont understand why cant get power to fuses as I have power in yellow & white wires from headlight relay.
Can you confirm if yellow wire goes to 56a or 56b on the relay?
