Number14
Sep 24 2021, 07:02 PM
I’ve read everything I can find here and elsewhere and had my pro mechanic try to tackle the problem including new injectors, mps testing, new fuel pump, high torque starter, and a test with a known good brain.
Car starts fine in the morning but it won’t start after a short (5-10) minute drive. Turns over but won’t fire. If I wait an hour it will start right up.
Really appreciate any insight to this problem.
Thanks.
jcd914
Sep 24 2021, 07:17 PM
There are many things that could contribute to your issue but if every thing else is good the following might be worth checking.
It sound like the heads are heat soaking after the is engine shut off, no more air flow. The short stop time isn't enough for the head and head temp sensor to cool down enough and the FI keeps the fuel mixture too lean for good restart.
There was a spacer available for the head temp sensor the helped with heat soak, allowed the temp sensor to cool faster than the head.
Jim
Number14
Sep 24 2021, 07:34 PM
Thank you, Jim. I’ll give that try.
brant
Sep 24 2021, 07:53 PM
Verify spark
Get a spare plug and pull a wire or… use a timing light when it is acting up
Does it run for long periods before you shut it off?
emerygt350
Sep 24 2021, 08:06 PM
I would look to ignition first. Have you tried starter fluid?
Number14
Sep 24 2021, 09:12 PM
Brant: generally, the shorter period of time it runs, the more likely it is not to start.
EmoryGT350: I have not tried starter fluid but my mechanic says he checked spark. I will mention this to him.
Thank you for your thoughtful responses.
emerygt350
Sep 25 2021, 07:06 AM
If starter fluid starts it, then look to fuel/fuel injection. If it doesn't, look to ignition.
Superhawk996
Sep 25 2021, 08:11 AM
QUOTE(emerygt350 @ Sep 25 2021, 09:06 AM)
And time to find a new mechanic that can do real diagnostics rather than throwing parts at a problem at your expense. Sheesh -- Modern "Mechanics"
Jett
Sep 25 2021, 08:47 AM
QUOTE(Superhawk996 @ Sep 25 2021, 07:11 AM)
+1 an experienced mechanic with the right tools and machines. Our 2.0 was running good but after measuring the TPS our mechanic realized that it would only travel 21 of the 25 clicks, bought a new panel from 914Rubber and is now running great
emerygt350
Sep 25 2021, 01:30 PM
Mine only gets 12 clicks
. Even after replacing the board with the 914rubber replacement. I just make sure they all count.
