QUOTE(914sgofast2 @ Sep 25 2021, 01:18 PM)
Any type of foam pad should be avoided. They will retain moisture and rust out the tank from the outside to the inside. I am using a sheet of epdm rubber I got from Grainger Supply and cut to fit the shape I wanted. It has adhesive on one side and was glued to the body, not the tank. People also use pieces of the green scotchbrite scouring pads, but they too will retain moisture.
I did the same, with non-adhesive neoprene rubber sheet material.
