Hi. My 74 1.8, 123ignition with single Weber 32/36 has developed a new sound. A buddy pointed it out and now I cannot unhear it. It seems to have started after a 15mi drive (long for me - I am still getting everything dialed in).
At all speeds under 2500 I get a steady tapping or knocking sound at the speed of the engine. It sounds louder on the passenger side but with the stethoscope #2 the valve tappety tapping sounds a bit louder than the others (-scope on the intake nuts). Not sure if it is a normal sound for a T4 engine.
Valves checked last weekend at .006. Timing 7.5 BTDC at idle. 123 increases advance linearly +22 between 1000 and 3200RPM (total advance 30). Plugs gapped. Carb tuned.
Compression at 1=120, 2=120, 3=100, 4=140.
I tried snugging up the exhaust manifold bolts (#2 was a bit loose) but no change.
Power is fine but it does backfire on deceleration.
Pic of plugs (1-4 bottom to top) below. 4 has some carbon.
I’d appreciate some insight. Different diagnostics? Ready for tear down? Nothing to worry about?
Thanks a ton.
