I was wondering if anyone has had any issues with the new 914Rubber 5pin relays.
I purchased 8 brand new WDG branded 914Rubber Black 5pin relays back in November of last year. I ohm checked 4 of my original OEM Wehrle brand pins between pins 85/86 and 30/87a. I have continuity between pins 30 and 87a and continuity between pins 85 and 86 on the OEM relays I have in front of me. Out of the 4 extras I have 1 has a reading of OL (no continuity) between pins 85 and 86. All 4 914Rubber relays have continuity between 30 and 87a.
Ohm readings are as follows:
4 OEM Relays 69 Ohms to 87.4 Ohms max between pins 85 and 86. All the relays show continuity when I use the continuity beep selection on my DVOM.
3 914Rubber WDG relays no continuity beep between pins 85 and 86 with ohm measurements 118.1, 117.5 and 120. 4 relay OL (Out of limit) between pins 85 and 86.
I will end up pulling out the other WDG relays I installed into the car to test them as well.
The issue I am having is when I plug the new relays into the headlight motor relay sockets, it blows the 16A fuse every time. When I plug the OEM Wehrle 911.615.109.01 relays most likely circa 1974 into the headlight motor relay sockets, the headlights raise and lower with no issues. I am also curious as to the warranty time frame on the relays. I still have all my original relays just in case.
