Speedo
Sep 27 2021, 03:07 PM
I need a replacement antenna parts (or an entire antenna) for my 6. Let me know what you have that would be correct. The parts I need are on the base...so if you have some base parts as extras, let me know. Pics of what I have...
Sep 27 2021, 03:36 PM
I have a new Hirschman chrome antenna - HIT AUTO 2040 $40 + ship.
DucRS
Sep 27 2021, 06:59 PM
If there’s a second one laying around, I’ll take it
Hoppie944s2
Sep 27 2021, 07:55 PM
Ditto, if no one takes it , I will take it
Speedo
Sep 30 2021, 11:19 AM
Does this look correct? Charles at Woodies claims this is correct...
https://www.ebay.com/itm/363469999223?mkevt...%2Cchnl%3Dmkcid
914Sixer
Sep 30 2021, 11:55 AM
Woodies are correct, HOWEVER most antennas were dealer installed. MEASURE diameter of your hole. Store has 2 different versions for the holes. You may find cable lead is too short and will require an extension.
I personally went with the more expensive Beru because it is stainless steel and has a replaceable cable lead. A200 is the model. This will ONLY work with SMALL HOLE.
Speedo
Sep 30 2021, 04:34 PM
Fender hole is right at 7/8ths.
Speedo
Oct 19 2021, 04:19 PM
Still looking for an original antenna that fits a 7/8ths hole.
914e
Oct 19 2021, 10:10 PM
QUOTE(Speedo @ Sep 30 2021, 03:39 PM)
QUOTE(Speedo @ Sep 27 2021, 01:07 PM)
Click to view attachment Click to view attachmentWhere was the hole drilled? That looks more like a Super Beetle antenna.
Speedo
Oct 24 2021, 05:46 PM
So I figured out what happened...and I still need some antenna parts. the area where the antenna attached was rotted and replaced. The replacement steel had an antenna hole but it was up higher on the fender and the mounting surface was more flat. Here is what I have...again, I need an antenna or parts to make mine work. Basically I need the plastic half sphere plastic and chrome cover.
Speedo
Oct 24 2021, 05:55 PM
Click to view attachmentSo I basically need the two items in the left of the picture for mounting on a flat surface vs the side of a hill...the plastic and the chrome cover. Or just the hole damn antenna if you have one.
PCA7GGR
Oct 24 2021, 07:58 PM
Will any of these parts help?
