QUOTE(wonkipop @ Sep 28 2021, 03:20 AM)
mine is a jan 74.
what is the T fitting you are describing also hooked up to besides the distributor retard hose and the hose into the intake plenum?
thats the vacuum retard side of the advance/retard if its facing the passenger side.
what you are describing is a bit different to mine.
but i have both ports connected on the throttle body.
curious about the hook up to the t fitting as that t fitting, in about that position, on mine has nothing to do with the dist advance retard, its a t fitting taking the fuel pressure regulator vacuum hose and the decel valve vacuum hose to the intake plenum.
It seems that I have two vacuum t-fittings. Someone before my time during my father's ownership (still current owner from new) seems to have added another vacuum T inline with the line that goes to the intake plenum (manifold vacuum) which a factory vacuum t-fitting is present and connected. Is the port that I show plugged off with a vacuum plug also manifold vacuum? If so I will delete the second t-fitting and reconnect the retard side (red dashed line) to the front port off the throttle body (where it seems it's supposed to go from factory). The advance side (blue dashed line) is attached to ported vacuum rear facing port off the throttle body currently.
