Rufus
Sep 29 2021, 05:50 PM
After searching treads on this and reviewing the suggested jackstand positions in the FAQ section, I still have questions.
I’m leery of jacking under either the engine or transmission since both are magnesium. Using my floor jack under the rear donut appears best for lifting, but prevents putting a stand there.
So I’m looking at putting stands under the pivot section of the radius / trailing arms in the rear. Does it matter where along the pivot’s length a stand is put?
Is another option under the rear strut where it attaches to the radius / trailing arm? … or maybe under the radius arm at the strut attachment (after wheel & tire removal)?
The front looks easier: either under the front donut, or the front A-arm pivot (as on my ‘67 911.)
Thanks in advance for any comments.
Bob S.
914Sixer
Sep 29 2021, 06:29 PM
DO NOT use jack stands WITHOUT safety pin to prevent collapse.
jcd914
Sep 29 2021, 10:42 PM
I use the rear trailing arm tube/shaft section often for jack stands.
I keep it toward the middle in the larger round section.
As 914sixer suggests, be smart about the jack stands you use.
I only have 1 pair that have pins but I only use the other pair on their lowest setting, so they can't collapse.
Jim
rhodyguy
Sep 30 2021, 06:23 AM
I wrap big zip ties over the lever (cheap insurance) and through the legs in those ratchet style ones but still leave the floor jacks raised and in place.
NARP74
Sep 30 2021, 09:54 AM
If you want max height, can leave the wheels on and better safety, I built a set of wheel cribs. I love them, built two different heights, they can be combined and with the two stacked up, I can easily get under my lowered car with a creeper and have room to work.
