That's another good one, Ian - I'm guessing there are a lot of AAR's that are beyond the soak-it-in-PB-Blaster approach.
Sea Rooster
Oct 1 2021, 01:54 PM
Good video.
I recommend putting the AAR valve in the freezer to see if the piston moves. Take a peek inside the valve to see how open it is before you put it in the cold then set it in the sun. Check for movement...
Medtner3
Oct 1 2021, 07:16 PM
QUOTE(iankarr @ Oct 1 2021, 11:43 AM)
Is your warm idle high? Auxiliary air regulator kaput? Here's how I rebuilt mine
