Ok, so ~ 10 days ago I installed temp sender....
Taco plate leaked like crazy. So tonight I drained oil and pulled it back apart.
choices:
1) re-install with new gasket and more sealer
2) put old cover back on and install the temp sender I got that replaces drain plug.
Issue taco plate sender says 200 deg and drain plug says 150 deg.
So what do I do? I could swap temp for oil presure too....
What would you do?
