68gator
Oct 5 2021, 12:13 PM
The car ran fine all summer. Just recently car started running real rich, plugs were horribly fouled, and when checking oil found lots of fuel in crankcase. Fuel regulator problem? The cold start valve has been inop since I have had the car (15 years), just lived without it. Thoughts please..
Dustin
Oct 5 2021, 01:50 PM
Leaking injector?
brant
Oct 5 2021, 01:57 PM
I agree....most likely a leaking injector
or now leaking CSV
68gator
Oct 5 2021, 03:46 PM
When I checked the plugs to try and isolate one cylinder, all four plugs are really fouled, so it seams like it is more than just coming from one injector. There is lots of fuel in the crankcase, the oil level on the dipstick rises noticeably. I changed out the oil, and only drive it 2-3 miles, running rich, and I can see the oil level is higher each time.
jcd914
Oct 5 2021, 04:12 PM
Bad air flow meter?
The air flap gets bent and drags so it can hang up and add more fuel than needed.
But also the fuel pressure regulator can leak and dump fuel into the intake through the vacuum line.
Jim
wonkipop
Oct 5 2021, 06:13 PM
QUOTE(jcd914 @ Oct 5 2021, 04:12 PM)
Bad air flow meter?
Jim
that sounds like a very good tip re fuel pressure regulator.
simple as disconnecting the vacuum hose to see if anything is coming out.
68gator
Oct 5 2021, 07:17 PM
QUOTE(wonkipop @ Oct 5 2021, 05:13 PM)
Bad air flow meter?
Jim
Thanks, I will check the flap so see if it moving freely.
TheCabinetmaker
Oct 5 2021, 07:36 PM
Does the 1.8 have a cold start valve?
L-Jet914
Oct 5 2021, 07:57 PM
QUOTE(TheCabinetmaker @ Oct 5 2021, 06:36 PM)
Yes the 1.8's have a cold start valve. I don't think mine has ever run in a while because it's never cold enough when I drive the car haha.
