KenH
Jul 26 2005, 11:59 PM
FYI
There are 2 915 LSDs on ebay.
Thay can easily be converted to Coarse Spline for the 901s for about $450 in new parts.
Ken
Aaron Cox
Jul 27 2005, 12:00 AM
im clueless at this stuff. but you arent able to use the fine spline shafts in a 901?
(i know you can use the 915 coarse spline ones in a 901)
KenH
Jul 27 2005, 09:12 AM
To the best of my knowledge all 901s have Coarse Splines. - - and some early 915s & 925s.
Ken
ClayPerrine
Jul 27 2005, 09:17 AM
QUOTE (KenH @ Jul 26 2005, 11:59 PM) |
FYI
Ken |
A 915 differental will not fit in a 901. The coarse splined 915 differental drive flange splines are the same as a 901, and the drive flanges will interchange.
But the differentals will not.
ArtechnikA
Jul 27 2005, 10:25 AM
can we get a link, or an item number?
i am shopping for 915 parts...
(late, if it matters...)
KenH
Jul 27 2005, 11:47 AM
ClayPerrine
Jul 27 2005, 12:24 PM
Ken,
It's not going to fit into a 901/914 transmission case.
But.. if you want to waste your money, don't let me stop you.
Aaron Cox
Jul 27 2005, 02:11 PM
one of the ads says it will... with modifications...
let him explain what needs to be modded clay....
KenH
Jul 27 2005, 03:42 PM
You remove the existing ring gear from your diff. You then bolt it to the LSD assembly. You will need to purchase different length bolts from your Porsche dealer.
You will have to set the backlash and preload.
The LSD itself is the same for 901 & 915s. The bolt patterns are the same - I know because I just did one.
The gears inside the LSD can be changed to fit either Coarse or Fine spline output shafts
Ken
Aaron Cox
Jul 27 2005, 03:47 PM
QUOTE (KenH @ Jul 27 2005, 02:42 PM) |
Ken |
very cool.
BUT - you cannot run fine spline output shafts through a 901 apparently?
KenH
Jul 27 2005, 03:59 PM
The C/V joint shafts that bolt to the Tranny have a coarse spline.
You could convert the half-shafts to fine spline but thats a bag of snakes.
The point here is a new ZF LSD is about $1700, 901 or 915.
Used 901 LSDs are seldom for sale.
The parts to convert a used 915 unit are about $450, so if you can get a used LSD at a "good" price you can save some money.
Ken
Aaron Cox
Jul 27 2005, 04:02 PM
Mueller
Jul 27 2005, 04:10 PM
ouch....who is 9M and can they please tone down the huge red fonts in their ads????
one of these days I'll be able to afford an LSD for my car
Aaron Cox
Jul 27 2005, 04:11 PM
can we say group buy? lol....
1500...plus a trans rebuild
TimT
Jul 27 2005, 04:37 PM
I have a Quaife915 torque biasing diff in my 901 box...it werks
KenH
Jul 27 2005, 06:25 PM
I just double checked and the Coarse Spline gears were only $270 for the pair.
Ken
TimT
Jul 27 2005, 06:55 PM
btw I got my quaife from a racer that had to remove it from his car to remain "stock"
$700
TimT
Jul 27 2005, 06:58 PM
Just looked at those Ebay links.. dunno how they make 930LSD work in a 901 box
the other LSD should work no problemo
