QUOTE(gereed75 @ Oct 9 2021, 04:42 AM)
I built a 2.4 Mod Solex cammed, 36mm ported, carbed motor. 9.5 compression JE pistons, reconditioned Mahle Biral cylinders, single plug. A really fun 7400 rpm street car motor that fits the spirit of early Porsche goodness. Feels like about 195 hp and a sweet torque band
You did not mention budget, so I am assuming yours is ample, so.....
Consider having the crank modded for improved oiling. I used Marine Crank in LA. Never worry about turning a bearing.
Probably the next biggest concern is whether to twin plug. Adds a fair amount of $ to the build. I run on pump gas no problem but I suspect the extra performance with 10.5 compression would be the cream on top, but I run only the stock oil cooler and am right on the limit of needing a second cooler, another $ trip point. Since you are going E cams (and E heads I assume) my suggestion is that the higher compression and twin plugging not worth it as cams will limit the performance benefit of the higher compression
Stock rods , flow modded stock oil pump and stock valve train will easily support the 7 grand rpm limit commensurate with the E cams
Ultimate performance and engine architecture is all about cam choice. Figure 180 hp.
Are you building or having someone do it? Picking suppliers is as important as any aspect of this. EBS was great to work with and can do a lot more than just supply parts
The plan is to sort out all the parts this winter, build the motor over next summer and put it into the car next winter. I hope to expense the parts and machining over over the winter so my wife is not to horrified by the costs.
I would like to to make a budget for it over the next few weeks.
Yes I will be putting in a oil cooler up front.
I am in BC so I am not sure where is the best place to get the crank and case machining done. I have a guy to do the head work, I would like to use Ollies but shipping might be costly.
I will be replacing the pistons with JEs and using Don for all my small parts.
I have not sourced a four rib pump yet, or determined if I can use the old pump.
I am not sure if it is necessary to shuffle pin the crank as I don't plan on getting rpm past 7000 before the cams run out of steam. ...But IF I miss a shift.
I will be having a local guy assemble it and re-jet the carbs after getting all the machining done.
I will get a std/std crank
I will plan on a single plug motor and will be using 94 Chevron gas.
