brer
Jul 27 2005, 10:50 AM
who knows how to tell the early 911 rear hubs, while in the console
from the later post 70 ones? how do you spot and early rear setup when its out of the car?
these would be for that 5 lug conversion.
thanks,
Jul 27 2005, 11:01 AM
QUOTE (brer @ Jul 27 2005, 09:50 AM) |
who knows how to tell the early 911 rear hubs, while in the console from the later post 70 ones? how do you spot and early rear setup when its out of the car? |
the early hubs fit the 914 wheel bearing.
take a tape measure and look for 42mm dia. at the part that goes into the wheel-bearing ...
Andy
brer
Jul 27 2005, 11:07 AM
the problem is....
there are many trailing arms with hubs in them. The owner of them will not let me pull the hubs out of the arms, says he cant sell them that way. so i have to ID them while together. what does and early arm look like?
brer
Jul 27 2005, 11:08 AM
would hubs from a 65/66 912 work?
davep
Jul 27 2005, 11:18 AM
I'm guessing a bit, however I think the really early hubs would not work; those up to 68 (short wheel base, shorter arms). You should be looking for steel arms I think. Later hubs have the centering ring on them also; 74 up perhaps and I believe these are aluminum arms.
Jul 27 2005, 11:21 AM
mine got a serial number on the back, kinda hard to read, but i *think* i got it right ...
901 331 57506
goose2
Jul 27 2005, 12:15 PM
If you're looking for early 911 hubs, I have some...they fit 914 trailing arms.
Eric_Shea
Jul 27 2005, 02:53 PM
Buy Randy's ...or... Dave's right (as usual) look for "Steel" arms. If you find a pair of steel arms with the rear swaybar ball you're probably safe.
