Mikey914
Oct 20 2021, 11:56 AM
We have been working on this for some time now and are going into production soon.
The brake reservoir covers. I had seen these in the past and since no one wants crud on the top of the reservoir to get into the system, I decided to make these.
I made these in 2 flavors, The thinner material like OEM and a material that is slightly thicker and looks more like the reservoir itself. The thicker one is the 1st prototype shown.
I did actually stumble across one being used in the wild at WCR too!
These will be ready in about a week. Pricing to follow shortly. You know me it will be reasonable.
Mark
Mikey914
In the wild
GregAmy
Oct 20 2021, 12:08 PM
You're right: I didn't.
rhodyguy
Oct 20 2021, 12:38 PM
Are you only producing the version with the overflow spigot? My cap on the 73' only has a hole. My guess is to prevent vacuum from building. The reservoir is solid around the top edge. No means for the fluid to escape. I think the spigot version requires a clear tube and the clamp differs.
FlacaProductions
Oct 20 2021, 12:39 PM
I've seen (pictures) of these in the past and tried to find them to no avail. Nice addition - I'm in.
mmichalik
Oct 20 2021, 12:44 PM
I'll take one as well.
Thanks!
ndfrigi
Oct 20 2021, 12:50 PM
1 for the ticker version for me sir Mark
StarBear
Oct 20 2021, 12:55 PM
I’m in for one of the thinner OEM type.
Had the car since new and don’t think it ever had one, or one of the first services just never replaced it.
Something similar to the dust cap inside the dizzy over the rotor. Very similar material and never to be found ( mine’s still there).
brant
Oct 20 2021, 01:34 PM
I run the old ones (aftermarket I believe) on both of my cars
but got them years and years ago.
Mark, if you need to see one as your prototyping... let me know
Mikey914
Oct 20 2021, 01:58 PM
QUOTE(rhodyguy @ Oct 20 2021, 11:38 AM)
There is a placement for the hole. They don't have to be cut out. It may be easiest just to request no hole for overflow when ordering.
jim_hoyland
Oct 20 2021, 04:11 PM
Saw Marks prototype at WCR last week; a very clean looking replacement.
PanelBilly
Oct 20 2021, 04:17 PM
I’d like one too. Thicker is fine with me.
scallyk9
Oct 20 2021, 04:43 PM
Please add me for one!
Montreal914
Oct 20 2021, 04:52 PM
Well, got to protect the area from the dirt.
In!
Puebloswatcop
Oct 20 2021, 05:00 PM
I'm in for 2. One oem and one thicker. Thanks Mark
914Sixer
Oct 20 2021, 05:24 PM
These were never a factory part. Always aftermarket. A good addition though.
Root_Werks
Oct 20 2021, 05:26 PM
Oh great, more stuff to buy from 914 Rubber!
StarBear
Oct 20 2021, 05:36 PM
QUOTE(914Sixer @ Oct 20 2021, 07:24 PM)
That might explain it. Mine has what looks like a hinge claw and a tab knob on the opposite side, so maybe another multi car use item with some cars having the cap and some not, depending on potential for dirt exposure?
yellowporky
Oct 20 2021, 05:56 PM
I will take a thicker one please
Jamie
Oct 20 2021, 05:59 PM
QUOTE(Mikey914 @ Oct 20 2021, 09:56 AM)
Mark
I've never had occasion to look, so is the 914 BF reservoir also used in any other cars such as VW's?
ClayPerrine
Oct 20 2021, 06:06 PM
Jett
Oct 20 2021, 06:12 PM
I’ll take four of these!
913B
Oct 20 2021, 08:51 PM
sure why not
Tdskip
Oct 20 2021, 09:15 PM
Neat
JamesM
Oct 20 2021, 10:16 PM
I will also be needing 4 of these.
rgolia
Oct 21 2021, 06:45 AM
Put me down for one. My 914, owned since new, did not come with one of these. Always looked like something was missing.
rgalla9146
Oct 21 2021, 06:53 AM
Never original equipment. An accessory.
As for venting.....or vacuum, early cars had a round shouldered non-vented cap and a
nipple on the resevoir with a drain hose toward the ground.
Later cars had a square shouldered vented cap. On these overflow was contained by
the perimeter wall on the top of the resevoir.
PS never push your caliper pistons back with a full resevoir and a vented cap on a late car.
You'll squirt brake fluid skyward.
rhodyguy
Oct 21 2021, 07:47 AM
Look on P.7 of your Haynes. Is the spout cast in to your cover?
gms
Oct 21 2021, 08:25 AM
This is a great after market product to recreate
(Not OEM)
djway
Oct 21 2021, 11:35 PM
thick
Van914
Oct 22 2021, 05:23 AM
I will take a thick one. I had one in the past. I think it came from Automotion.
Thanks
Jack Standz
Oct 22 2021, 09:52 AM
One thick and one thin for me please.
Jim C
Oct 22 2021, 10:05 AM
I'm in for 1 thick.
mlmgm
Oct 22 2021, 10:34 AM
Two thick caps please
Mikey914
Oct 22 2021, 12:42 PM
QUOTE(rhodyguy @ Oct 21 2021, 06:47 AM)
The cover has a notch that gets cut out if you have the spigot. It slips over it nicely but will require you to remove the hose and reinstall it after the cover is on. You can see the one we saw at WCR was cut for it and didn't have the overflow. The more opaque version I made (thicker) makes it hard to see as the reservoir is new and the same material. I'll get some better pics up next week.
Mark
Pappy1975
Oct 22 2021, 01:54 PM
Mark,
I’ll take 1 thicker version.
abes914
Oct 22 2021, 02:26 PM
I am in. Thicker version as well.
Thanks
Mikey914
Oct 22 2021, 08:33 PM
PMs sent to all so far
FlacaProductions
Oct 22 2021, 09:36 PM
Hey
@Mikey914 - no PM from you in my box….
adolimpio
Oct 23 2021, 05:57 AM
I will take a thicker one please.
frostyf
Oct 23 2021, 07:42 AM
Thick one for me please
Mikey914
Oct 23 2021, 08:02 AM
QUOTE(FlacaProductions @ Oct 22 2021, 08:36 PM)
Hey
I'm sorry wrong thread. I meant to put this on the grill and seal GB.
These are still in production.. will be ready soon.
I'm posting up on phone as I'm on the road and I dorked ot up.
Sorry
PCH
Oct 24 2021, 03:16 PM
I'm in.
Gatornapper
Oct 24 2021, 03:37 PM
Mark -
Put me down for a thick one.
Thanks,
GN
jims914
Oct 24 2021, 04:20 PM
QUOTE(Gatornapper @ Oct 24 2021, 02:37 PM)
Mark -
Thanks,
GN
Mark,
Thin or thick.
The one i have form Automotion was thin.
jims914
Oct 24 2021, 04:21 PM
QUOTE(jims914 @ Oct 24 2021, 03:20 PM)
Mark -
Thanks,
GN
Mark,
Thin or thick.
Mark,
And I will take one.
Thanks
Mikey914
Oct 24 2021, 04:56 PM
Good news is the prices will be less, looks like an old paper catalog.
dyw914
Oct 24 2021, 05:41 PM
I will take one. Thanks.
L-Jet914
Oct 24 2021, 11:19 PM
Mark -
Thanks,
GN
Mark,
Thin or thick.
That's where I saw those years ago through the Automotion/Performance Products catalog. I knew I saw those somewhere as an aftermarket option. Glad to see Mark at 914Rubber is recreating a great accessory. With all that in mind put me in for two of the thicker style ones.
jonferns
Oct 25 2021, 10:55 AM
I'll take one of these
