Hi All,
With the rain finally coming to California, I am keeping the 914 in the garage and working out my winter plan for working on my 914.
I am currently in the middle of getting the heater back online but I also want to finally finish the fuel odor I still have.
I know from this post (http://www.914world.com/bbs2/index.php?showtopic=108524) that the charcoal filter is meant to go in the engine compartment on my 1975. However, the smell is in the frunk, not too bad and not nearly as bad when I first got my 914. When I first had the car, I saw that I had several serious fuel leaks at the carbs, fixed that. Then I took the fuel tank out last year and cleaned it out and redid all the hose and that knocked the fuel smell down I use to have in the car and the garage.
But I still have a pretty strong fuel odor in the frunk when open. I had the car with the mechanic to replace the oil cooler (I don't have the space to drop the engine myself) and to check out the fuel odors. He said that there were a few small fuel leaks in the engine compartment that he handled and tested the fuel tank, which didn't have any leaks. I was missing the charcoal canister, which I will be getting soon.
Here is my question, if the fuel odor is in the front, should I place the charcoal canister up front? Not sure I see the point putting it in the back. The fuel tank expansion tank has a nib that has a rubber cover on it and I am thinking that is where I would connect the canister, but I am not 100% sure and don't want to waste time. Any suggestions would be much appreciated.
Thanks in advance!
