ballsyfacts914
Oct 23 2021, 12:32 PM
Hi All,
Based on the attached diagram, I have confirmed the plastic fuel vapor line (blue) and the 13 mm hose (green) connection to the fan shroud.
What I don't have is the air cleaner as my car is carbed now. So where does the green hose from the charcoal canister go?
Pictures would be rad!
Thank you,
rhodyguy
Oct 23 2021, 01:03 PM
Follow the green line. You'll have to draw off of the canister with the carbs.
ballsyfacts914
Oct 23 2021, 02:43 PM
QUOTE(rhodyguy @ Oct 23 2021, 02:03 PM)
Ahhh...So I split the green line from the canister to the carbs and the again to accommodate the fuel line and the vapor line?
Thank you!
