QUOTE(speed metal army @ Oct 25 2021, 07:29 PM)
If the gauge is grounding out, it will peg. Check to see that the signal wire is all good. You didnt daisy the signal off the idiot light did you? That will also do it.
It was working, then stopped after I fixed the grounding for the sender. Gave up the ghost I guess. My wires all checked out and the gauges are ok too. No daisy chain, all new wires in a home run. I'll look for a sender tomorrow, then the light and the 2 gauges will work again instead of 2 of the 3 working.
