I am rebuilding a pedal cluster for a member on the Pelican site with a 911.
He sent two clusters to make one and they had two different shafts.
They are the same overall length.
The one that is not straight on the end is from the 914.
I think the straight one is from a 911 but I don't know what year.
Also when you line up the holes where the roll pin goes they are offset slightly.
So my questions are:
Which one should I use
If I go with the 914 one will it work in a 911
Thanks, Dean
