QUOTE(9146C @ Oct 29 2021, 02:41 PM)
I'll start by saying this is not a mod that I've tried...(I actually deleted my side lights).
Some time ago, I had read a thread (don't remember where) that in some parts of the world, this (flashing side marker lights) was a factory delivered option...it was something to do with the ground wiring...I don't recall the details.
Here is an old post from Pelican that describes a procedure:
http://forums.pelicanparts.com/porsche-914...rn-signals.htmlJust passing along...not my procedure and not tested by me.
Finally found the ground wiring post:
Incidentally you are meant to be able to change the front side markers to be indicator repeaters - ie, flash with the turn signal - but still function as a side marker - by changing the wiring of the side marker bulb so that the earth/ground is connected to the +ve for the turn signal instead.
I do not understand the '+ve' reference...any ideas?
