QUOTE(Literati914 @ Oct 30 2021, 12:15 AM)
….anyone have some pretty solid measurements for where the floor-mounted brackets (that hold the actual seat hinge) are to be placed/welded to the floor.
I can measure for you but let me suggest this.
Don't count on measurements. Too much variance in chassis, seat frames, and the position of the ratchet combs.
When I did buy my floorpan, the brackets were already on the floor pan. However, in the end you can't be exactly certain where the floor pan will "land" w.r.t to the rest of the sheet metal.
I welded the actual hinges on AFTER the floor pan was positioned. The hinge brackets that go to the floorpan only need to be approximate. You can determine where this approximate location is with the bottom of the seat bracket.
I determined where the actual hinges needed to be by trial fitting the seat bracets with the ratchet combs in place as Mate914 states. There is a bit of spring deflection for the seat angle adjustment lever that also comes into play as the whole thing was trial fitted.
Tacked hinges in place -- then refitted the seat brackets again to ensure they were correct.
Then final welded hinges.
Will mesure for you if you still wish but what worked on my car may not work on yours.
Mock up usually better than measurements.
