QUOTE(Luke M @ Oct 30 2021, 07:58 AM)
QUOTE(DaveO90s4 @ Oct 30 2021, 04:44 AM)
Any compelling views to the contrary?
Thanks
Dave
I haven't tried to find any nos bolts so I have used old ones with no issues.
However, I would not simply use a regular shank bolt. The OEM expansion bolt is designed to stretch a very specific amount under the prescribed torque. In addition the OEM bolt is a vastly better design than a common shank bolt. That stretch of the bolt is what keeps the flange from loosening due to cyclic torque applied to it.
Click to view attachmentThe OEM expansion bolt is necked down after the thread form to eliminate stress risers that can orginate from the root of the threads.
I don't know what the material grade is but I'd bet it is probably closer to 10.9 rather than a 8.8 (Grade 5 SAE). In modern chassis and powertrain applications, highly stressed bolts (like an expansion bolt) would typically be 10.9.
If you use a standard shank bolt, you will not get the same stretch (i.e. clamp load) from the bolt as you will with the OEM expansion bolt at the prescribed torque.
Given that you have yielded your OEM expansion bolt, Do Not reuse that one. Find a used one on the forum. If you can't find one - PM me. I know I have some in storage . . . . where is a whole different question
