QUOTE(BeatNavy @ Oct 31 2021, 10:57 AM)
I'm tempted to go with Chris' remote oil cooler solution at some point. Based on his advice I'm pretty sure at lot of my hot oil is bypassing my remote cooler
I installed both the relief valve and the remote cooler; stuck the latter up under the right rear, with the fan. I'm even controlling the fan relay via the Microsquirt (I have a separate oil temp sensor in the cooler return line)...Not one cooling problem all summer. Ran around 210-215 max.
We discussed this back in 2020? in your oil cooler thread, but my original problem was really bad, like running into the red on the stock gauge. I suggest that a lot of it was from some unknown issues I was having with the engine, whikch became less an issue when I had another longblock built over the winter.
But for $100 and (maybe) 15 minutes' work you can install Chris' valve and know for sure it's right.
