Folks,
I'm still getting use to my 914 and loving this ride. Still have some sorting to do and starting with a tune up and fluid changes.
I've search this site multiple times looking for tune up numbers for a 2.4 FAT Performance engine and can't get clear data. The engine has Weber carbs, MSD, and Tech Adapt. This 2.4 engine was originally a 2.0 Type 4. Do I use the original spec numbers for a factory 2.0 engine or something different? Chime in if you know the numbers or can help get me up to speed on tuning this engine. I kindly request numbers for the following:
Valve clearance?
Spark plug gap?
Points setting?
Desired Dwell numbers/range?
Timing advance in degrees BTDC to set on my timing light with engine at 3200 RPMs?
Thanks much!
Magic
