QUOTE(Luke M @ Nov 6 2021, 09:38 PM)
I just fitted a Momo 8002 to my brothers 74 914. It too was a tight fit. It would only start and stop on the splines. I ended up cleaning both the steer shaft and hub splines with a round wire brush then sprayed a little wd40 on the splines. The hub goes on and comes off no problem now. I also had to open up the horn contact hole that goes through the hub. It was way off by a good 1/8''. The QC at Momo has gone down the tubes.
Filed the end grooves and wire brushed the internal section. Used Kyrtox on the steering shaft splines. I worked it on and off with a fair amount of effort needed to back it off.
Still not satisfied with the fit but it will come off more easily with a wheel attached.
(The upper Circlip #3 is the stop for the hub for any wheel.)
I did drill the wire hole as this one was similar in condition to yours. A poor casting or finishing step.
It will work but I'm not impressed.
To be continued....
