QUOTE(nditiz1 @ Nov 4 2021, 03:52 PM)
@ClayPerrine - so I might be using a 78/79 which comes with plastic lines. I believe those can be swapped to metal. As far as the other metal ones I'm confused. If have metal lines in the tunnel. I'm going to relocate my FP to the frunk somewhere. Are you saying I need metal lines from the tangerine lines into the accumulator?
Mount the fuel pump up front. Looking at a 911 CIS pump...
You will note that the pressure connection is a threaded fitting. It actually hooks to a Braided steel line with a banjo fitting on the end. You will need to braise a threaded fitting to match the braided steel line onto the pressure line steel tubing running through the tunnel.
On the other end, you will need to braise a threaded fitting onto the pressure line to hook up the CIS fuel filter. Here is an image of a 911 CIS fuel filter/Accumulator setup.
From there you can use the 911 steel tube to connect up the fuel accumulator. From the accumulator, you run the factory 911 braided steel fuel line to the fuel distributor.
For the return line, you need t braise a fitting on to the steel line in the engine compartment going back to the tank. The tank end of the return line can be a high pressure rubber fuel injection hose.
I hope that helps.
Clay
