cgnj
Nov 5 2021, 11:57 AM
Been trying for 3-4 days to get consistent lift readings. Before I toss in the towel and say close enough, can You post pics of the fixture you used to measure your lift.
TIA,
Carlos
nditiz1
Nov 5 2021, 12:06 PM
bkrantz
Nov 5 2021, 07:44 PM
I bolted a steel plate to the head intake face, and then used my dial gauge on an arm with a magnetic base. I also cycled the crank through a complete turn after making any changes before measuring lift.
Olympic 914
Nov 6 2021, 08:32 AM
You want to be sure that the indicator is parallel to the valve stem.
Used a setup similar to Bkrantz
barefoot
Nov 6 2021, 11:24 AM
I'm kinda cheep, so here's mine, bought dial indicator off Amazon & fabed the wood block. Had a metal angle piece in my junk pile
Had to position indicator tip carefully on the retainer:
