SOLD
This is a mostly complete engine from a 77 - 6272470 - 911/85. The case is a 7R that has been partially torn down. It was torn down due to 4 broken head studs as seen in the pics below. The missing pieces are minor ones like rocker shafts and rockers, tstat. Cylinders appear to be the better Nikasil ones. Heads are actually 2.2 10/69 date. Heads matched to cylinders and case. Head bore ~106mm. Intake 32mm and 33mm exhaust no CIS ports. Cylinders 90mm inner bore.
What all is included:
Short Block
6 matching heads
6 matching cylinders
Fan and shroud
Engine shroud
Chain cases
Alternator
CIS intake
Cam towers
Cams
Engine sheet metal
engine mounting crossbar/carrier
Oil cooler
Chain
Sprockets
$2,500 obo
