QUOTE(mmichalik @ Nov 6 2021, 08:05 PM)
I had the same problem with mine. Wiring for the LED is specific. The regular bulb will work with the wires connected to either terminal.
If it's not working, you'll have to switch the wires on the back of the light socket.
It should work then.
It is somewhat common for these older vehicles that the wires were disconnected and reconnected at some time during repairs or body work. The socket has 2 spades and 2 wires connect to them and sometimes the wires are reversed.
If reversed, the voltage on the bulb is reversed and the button of the bulb base is ground and the case is 12V. An incandescent bulb is not polarity sensitive and works regardless of the wiring. The LEDs are diodes and current only flows in one direction.
I've worked with a couple of folks with 911 front sidemarkers with the same issue. Also on the 911 the 3rd brake light can be wired in reverse. One guy was so adamant that I wired the LED 3rd brake light backwards that he cut the wires on the LED board and reversed them.
