partwerks
Nov 7 2021, 08:04 AM
Looking to buy just one rear Bilstein shock.
bdstone914
Nov 7 2021, 08:55 AM
QUOTE(partwerks @ Nov 7 2021, 07:04 AM)
What is the part numbet of the one you need? There are different models. I think i have some singles and
@partswerks
partwerks
Nov 7 2021, 09:04 AM
QUOTE(bdstone914 @ Nov 7 2021, 06:55 AM)
@partswerks
Where is the part number located? I can take a look.
bdstone914
Nov 7 2021, 09:07 AM
QUOTE(partwerks @ Nov 7 2021, 08:04 AM)
@partswerks
I think it is stamped near the bottom of the shock
partwerks
Nov 7 2021, 08:27 PM
QUOTE(bdstone914 @ Nov 7 2021, 07:07 AM)
@partswerks
I see a number 18 towards the bottom, and visible from the back of the car.
Literati914
Nov 8 2021, 09:07 AM
Hey Lyle, the number will be like this:
partwerks
Nov 8 2021, 09:35 AM
QUOTE(Literati914 @ Nov 8 2021, 07:07 AM)
Doug,
1790043702
Hoppie944s2
Nov 8 2021, 10:12 AM
Any Bilstein pairs for the rear that you are selling?
Literati914
Nov 8 2021, 06:50 PM
QUOTE(partwerks @ Nov 8 2021, 10:35 AM)
Doug,
1790043702
Beats me.. I can’t find a bilstein with either my number or yours.
partwerks
Nov 8 2021, 09:14 PM
QUOTE(Literati914 @ Nov 8 2021, 04:50 PM)
Doug,
1790043702
I was missing one number, but still no difference. 17900943702
Literati914
Nov 8 2021, 11:23 PM
Lyle, your rear Bilsteins have a coil over set up, correct? Could there be a number hiding under the outer threaded sleeve?
..also, your car is set up with a V8 and Porsche 6 speed… would that make since then that the rear shocks are the Heavy Duty bilstein? Or since they’re now leaking, perhaps they should be?
partwerks
Nov 12 2021, 10:28 PM
QUOTE(Literati914 @ Nov 8 2021, 09:23 PM)
How do I get those slid up to see if there is a number under them?
Literati914
Nov 13 2021, 11:14 AM
Probably gonna take a bit of disassembly, but there may be a set screw holding the sleeve… but even at full extension the sleeve may not move up high enough for you to be able to tell. Not a big deal really though, you could pull a shock and break it down, re-install in about an hour I’m sure.
Those numbers at the bottom that are etched, are not consistent with any of the modern numbers .. except the ‘179’ part, which does seem to be the common theme with bilsteins for the 914 - that’s what I’ve noticed anyway.
