QUOTE(rhodyguy @ Nov 8 2021, 11:16 AM)
The springs that control the L/R movement and the dentent plate may have been replaced with the ones that came with the SS kit. Super stiff. Thicker. Overkill. Check the condition of the detent plate for wear on the lever contact point. More often than not the plates are spent. Do you have to push really hard going to the R/1 plane? Always grind a bit? Short shift" doesn't nessesarily mean 'speed shift'.
yes. 1st and reverse take a concerted effort. seems the higher the speed, the easier the shifting.You guys are great! thanks again for your thoughts on this matter! I am following the steps of a post I read here on changing out the worn bushings on the shifting linkage. I would like to put the shifter back to stock for a more pleasant shifting experience.
