jim_hoyland
Nov 9 2021, 01:33 PM
The shaft of the clutch pedal barely rubs against the floor plate. It’s not a serious rub, but it makes a squeak….
I’d like to rotate the shaft an 1/8” inward( doable ?
Nov 9 2021, 01:47 PM
I would take a file or sander to the plate and make a little more room. That is if yo can’t shift the plate a little in the mount.
ndfrigi
Nov 9 2021, 02:42 PM
Hi Jim, maybe just need to adjust it by turning it counterclockwise?
sixnotfour
Nov 9 2021, 02:52 PM
QUOTE(ndfrigi @ Nov 9 2021, 01:42 PM)
Yup its crooked
SO.O.C914er
Nov 9 2021, 05:09 PM
Jim just take a little bit of meat off that floor plate and give yourself some room. This will also make it easier to take out and put back in.
sixnotfour
Nov 9 2021, 05:12 PM
Threaded and lock Nut...loosen adjust ..tighten..
jim_hoyland
Nov 9 2021, 06:26 PM
QUOTE(sixnotfour @ Nov 9 2021, 03:12 PM)
Thanks Jeff; just what I wanted to see
bdstone914
Nov 10 2021, 04:04 PM
It looks like the clutch pedal needs to be rotated slightly counter clockwise. That will make for less clearance. See if you can shift the board to the right. If not open the hole for the pedal.
Also see how far into the lower arm the pedal extends. The threads only need to be flush with the bottom. Too far in weil reduce the clearance.
jim_hoyland
Nov 10 2021, 09:38 PM
QUOTE(bdstone914 @ Nov 10 2021, 02:04 PM)
Thanks. I ended up enlarging the hole…
SO.O.C914er
Nov 10 2021, 10:23 PM
Jim talk to you about this in detail on Saturday. More thoughts on how to give more adjustment room.
