Anyone thrifty enough to know where to get just the cup seal for the ram on a floor Jack? Click to view attachment Thanks
Bullethead
Nov 13 2021, 12:34 PM
Try Grainger or a hydraulic supplies house. What are the measurements?
shane
Nov 13 2021, 12:53 PM
QUOTE(Bullethead @ Nov 13 2021, 10:34 AM)
ID: 1.2in-32mmish OD: 1.5in-40mmish Old 3-1/2ton powerbuilt jack model#647530
shane
Nov 13 2021, 02:24 PM
No expert on hydraulic stuff here but Grainger has these for replacement single and double acting hydraulic ram seals. Sizes seem possibly good and cost is $6-$8 bucks. Thinking these seals (Piston T-Seal, Piston Crown Seal) are just a better type of seal then the original that was used? Have to also figure out if I would need a single or double acting seal? The T-Seal says both while the Crown Seal mentions about double acting hydraulic cylinders only? Can’t find a seal on the Grainger site that looks like the original.
shane
Nov 13 2021, 02:29 PM
No expert on hydraulic stuff here but Grainger has these for replacement single and double acting hydraulic ram seals. Sizes seem possibly good and cost is $6-$8 bucks. Thinking these seals (Piston T-Seal, Piston Crown Seal) are just a better type of seal then the original that was used? Have to also figure out if I would need a single or double acting seal? The T-Seal says both while the Crown Seal mentions about double acting hydraulic cylinders only? Can’t find a seal on the Grainger site that looks like the original the one in the picture below that has a O-Ring inside the plastic ring.[attachmentid=814649Click to view attachment
